Activity Forums Apple Final Cut Pro Legacy Adding Audio to Quicktime
  • Adding Audio to Quicktime
    Posted by William Gum on May 25, 2005 at 8:54 pm
    I tried posting on the Quicktime forum but there seems to some problems.
    I am trying to add Audio to a Quicktime clip using Quicktime 7. I followed the instructions as outlined in the help file.
    File > Open File (audio .aiff)
    Edit > Select All
    Edit > Copy
    Open the Movie
    Edit > Add (audio file)
    Both audio file and movie are okay and play them. However, when I follow the above procedure, it does not work. The audio file is an .aiff and the movie is a mpeg2 file.
    The above worked when I used Quicktime 6.5.
    Any suggestions?
    W Gum
    Pdr replied 21 years, 4 months ago 2 Members · 3 Replies
  • Pdr
    May 25, 2005 at 11:15 pm
    Hi William
    I think this is because it is an MPEG2 file; MPEG2 files cannot contain separate video and audio tracks; instead, if they have audio, these files tracks have to be interleaved, or muxed.
    So you have two options:
    Firstly. you can export the MPEG2 file as a QuickTime movie
    — then add the soundtrack as you have in the past.
    Alternatively, you could use a product like:
  • William Gum
    May 25, 2005 at 11:42 pm
    Peter
    Thanks for the suggestion. It worked
    Bill
  • Pdr
    May 26, 2005 at 12:15 am
    No problem! Happy to help!
    Regards
    Peter
    Peter Dominic Ryan – Freelance Editor
    raycity* media – pdr@raycity.com
    PowerMac G5 Dual 2.0 GHz, 4GB, Mac OS X 10.4
    FCP HD 4.5, Motion 1.01, DVD SP 4
