Activity Forums DVD Authoring Adding audio files to compliant MPEGs
  • Adding audio files to compliant MPEGs
    Posted by Larry Sherwood on August 1, 2005 at 11:45 pm
    As my business of transferring 8mm home movies continues on, I’ve had several requests to add background music to the transfer. Right now I transfer direct to DVD from my pany DV30 via firewire. If I need to customize menus, I use Ulead MovieFactory to rip the MPEGs from the DVD, create my customized menus and then burn the DVD. Ulead has a setting that will not re-encode compliant MPEGs, which I have, so this workflow is very quick and easy. But, as soon as I add music in Ulead, it does re-encode my MPEGs which doesn’t look as good as the originals. Has anyone had experience combining compliant MPEGs with music and then burning back to DVD?
    Thanx
    LS
    Chris Borjis replied 21 years, 1 month ago 2 Members · 3 Replies
  • Chris Borjis
    August 2, 2005 at 4:14 pm
    I do this a lot for home movie transfers.
    I go directly from a camera live to the DVD-Recorder though
    and skip the tape step. If music is to be added, I record
    to DVD-RAM then rip/demux the .m2v video streams.
    I bring those into ReelDVD then drop the music right
    over it. I made a DVD-ROM full of licensed music with
    both pcm .wav files and dolby .ac3 files. I always use
    the .ac3 files to keep compatability and playback to
    a maximum. Then I build the disc from ReelDVD and burn it. Done.
    simply adding audio streams to an mpeg2 video only stream should
    not require any re-encoding. I wonder if there is an option somewhere
    in ulead to turn it off.
  • Larry Sherwood
    August 2, 2005 at 5:30 pm
    Hi Boris, thanks for the reply. I am basically doing exactly as you are, I am recording live thru my camera to my DVD recorder, not going to tape, onto a DVD-R. I use Ulead MovieFactory to rip the MPEGs from the DVD-R.
    I can see how I could add a single music track to each of the ripped MPEGs but what I want to do is add a music track to a series of MPEGs not just a single MPEG. In other words each 50 ft. reel creates an MPEG about 3 minutes or so, I end up with about 15 or 16 MPEGs on a DVD. I want to add about 10 tracks of music to cover all of the MPEGs so the music does not actually begin/end with each individual file.
    Thanx
    LS
  • Chris Borjis
    August 3, 2005 at 12:11 am
    I’m doing what you describe with ReelDVD.
