Activity › Forums › VEGAS Pro › Adding audio codecs in vegas – can this be done?
  • Adding audio codecs in vegas – can this be done?
    Posted by Lxmxfxd on October 19, 2005 at 9:02 pm
    I’m using vegas 6.0 – and the only codecs available are windows media 9.1 – I need to encode in 9.0 – is there a way to install older codecs so that vegas can encode in these older formats? I’ve downloaded and installed a pack from MS that includes the older codecs – is there a way to get vegas to recognize these newly installed (older) codecs?
    Lxmxfxd replied 20 years, 11 months ago 2 Members · 2 Replies
  • James_j
    October 22, 2005 at 12:12 pm
    Don’t take this answer as gospel, but I doubt it. Codecs especially, once installed, update all the necessary files.
    I suppose you could always install a virtual machine and be very careful to only upgrade as far as v9. Be real tricky though.
    A whole other question is: What’s the big difference supposed to be between 9.0 and 9.1? I just tried a test render and all I can get it identified as is WMV9. Why even try to use an older, presumably inferior, codec especially these days when everyone’s got their machines updating automatically?
  • Lxmxfxd
    October 22, 2005 at 8:19 pm
    The reason being that I need to merge files together and the original files are all wmv7.0 with wma 9.0. I need to merge them with a new rendered intro but they just wont merge unless the audio is 9.0 – I still can’t figure this one out.
