adding Arabic subtitle
After I added subtitle track and set the language to AR I tried to add subtitle in Arabic when typing or pasting Arabic words into the subtitle area the litters always get separated and change to the opposite direction meaning (lift to right) instead of right to lift even if I right click on the background of the character box and adjust the properties to (right to lift) and Arabic settings the setting change back to default (lift to right) as soon as I click else where
help please
thank you
