Activity › Forums › Adobe After Effects Expressions › Adding Anticipation, Overshoot, Bounce with dropdown menu
  • Adding Anticipation, Overshoot, Bounce with dropdown menu
    Posted by Dominique Parisi on May 7, 2020 at 12:38 pm
    Hi !
    I have been playing around with this script Dan wrote earlier this years, but I’m trying to add “””functionalities””” to it.
    As a reel thickheaded at coding, I’m turning to you guy’s for a bit of enlightenment
    Already have I played with this, adding a dropdown menu allowing me to switch between linear, ease, ease in, ease out. (only put the linear part of the code)
    I would like to add the possibility to have a anticipation before the animation or overshoot bounce, after the animation.
    I have stumble upon “inertial bounce” and “bounce back” expression from Dan , tried to play with them but had unforeseen mishap. (like jumping to the end position value without smooth mouvement. )
    Could it be possible to blend those expression to be able to switch between the animation type with a dropdown menu ?
    Thx to anyone who answer ( even “no it’s not” ???? )
    //moveAmt is defined by the length of another composition
    // Starpos is defined by a slider control in a "control-comp"
    if (dropMenu == 1) {
    if (m.numKeys > 0) {
    n = m.nearestKey(time).index;
    if (time < m.key(n).time) n--;
    accum = 0;
    y = 0;
    if (n > 0){
    if ( n > 1){
    for (i = 1; i < n; i++){
    if (m.key(i).comment == "Move") accum += moveAmt
    if (m.key(n).comment == "Move"){
    t = time - m.key(n).time;
    y = linear(t,0,m.key(n).duration,0,moveAmt);
    val = value + y + accum + StarPos ;
    val
    Victor Nash replied 1 day, 7 hours ago 2 Members · 1 Reply
  • Victor Nash
    September 27, 2026 at 3:53 pm
    This is an old post, but while I was researching building an expression with Anticipation with Inertial Bounce I saw this. I did work on building out an expression (not a dropdown), so I hope this helps anyone looking. works on 2D, 3D
    // RUBBER-BAND ANTICIPATION + INERTIAL BOUNCE
    // ANTICIPATION
    anticipationAmount = 30;
    anticipationTime = 0.20;
    anticipationPull = 1;
    // BOUNCE
    bounceAmount = 50;
    bounceSpeed = 3;
    bounceFreq = .8;
    bounceDecay = 4;
    if (numKeys < 2){
    value;
    }else{
    k = nearestKey(time).index;
    if (key(k).time > time) k–;
    k = Math.max(1, Math.min(k, numKeys – 1));
    t1 = key(k).time;
    t2 = key(k + 1).time;
    p1 = key(k).value;
    p2 = key(k + 1).value;
    // PATH DIRECTION
    path = p2 – p1;
    dist = length(path);
    if (dist > 0){
    dir = path / dist;
    }else{
    dir = p2 – p2;
    // ANTICIPATION
    ant = Math.min(
    anticipationTime,
    (t2 – t1) * 0.4
    antEnd = t1 + ant;
    if (time < t1){
    p1;
    }else if (time < antEnd){
    // Pull backward quickly
    u = (time – t1) / ant;
    pull = 1 – Math.pow(
    1 – u,
    anticipationPull
    p1 – dir * anticipationAmount * pull;
    }else if (time < t2){
    // Accelerate INTO the second keyframe.
    // No ease-out at the destination.
    u = (time – antEnd) / (t2 – antEnd);
    startPos = p1 – dir * anticipationAmount;
    forwardDist = dist + anticipationAmount;
    baseSpeed = dist / (t2 – t1);
    s = baseSpeed * (t2 – antEnd) / forwardDist;
    s = Math.max(0, Math.min(3, s));
    // Starts gently, accelerates,
    // and arrives at full speed.
    f = (s – 2) * u * u * u
    + (3 – s) * u * u;
    startPos + (p2 – startPos) * f;
    }else{
    // INERTIAL BOUNCE
    elapsed = time – t2;
    bounce =
    Math.sin(
    elapsed *
    bounceSpeed *
    bounceFreq *
    Math.PI * 2
    Math.exp(
    -bounceDecay * elapsed
    p2 + dir * bounceAmount * bounce;
