Activity › Forums › Avid Media Composer › Adding and Nesting effects
  • Adding and Nesting effects
    Posted by Uli Kunkel on March 15, 2007 at 12:39 am
    I can add an effect to a clip without a problem. Could someone please step me through the process of adding additional effects to the same clip?
    Also, how can I easily keyframe the separate parameters for those effects, and where do those keyframes show up?
    Thanks.
    Jon Zanone replied 19 years, 6 months ago 2 Members · 1 Reply
  • Jon Zanone
    March 15, 2007 at 6:07 pm
    To add multiple effects, simply hold down the alt (pc)or option (mac) key whilst you drag.
    To edit those efects, you must step into your video track:
    -make sure the video track you want to step into is active (selected)
    -on the bottom right hand part of the timeline window, there are two triangles. One is upside down. Click on the upside down triangle to step into the track. Click on the right side up triangle to step out. If you are in really deep, you’ll need to click several times to get in or out.
    Jon
