Activity › Forums › Adobe After Effects Expressions › adding an expression to multiple layers…
  • adding an expression to multiple layers…
    Posted by Erin Shelby on March 30, 2006 at 6:12 am
    hi, I wanted to add a simple wiggle expression on the rotation property to many layers, all the same expression “wiggle(5,10)” … I tried just pasting, but that didn’t work. I could copy a keyframe and the expression, but then the other layers got the keyframe info as well and that doesn’t work for me because all the elements already are at specific rotations I’d like them to wiggle from.
    Erin Shelby replied 20 years, 6 months ago 2 Members · 3 Replies
  • Mike Clasby
    March 30, 2006 at 6:20 am
    What version of AE do you have?
    I think it was AE6.5 and up for this:
    Highlight the Property (Position?)
    Edit > Copy Expression Only
    then Select the layer(s) you want to Paste the expression into,
    Paste
    and it will put the expression on the correct property,
  • Mike Clasby
    March 30, 2006 at 6:21 am
    I re-read you post, opps, Rotation property obviously.
  • Erin Shelby
    March 30, 2006 at 6:48 am
    wow, thanks!
