Activity › Forums › Adobe After Effects › Adding an effect to a part of the screen.
  • Michael Szalapski
    July 19, 2011 at 2:54 pm
    Many ways to do stuff like this. One way is to put a mask on an adjustment layer with the effect applied to it.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Greg Burrus
    If the effect is applied to an adjustment layer above you can make a mask above your footage using the mask tool to section off an area. Then you could add some feather to it so it has a smooth drop off unless you want sharp edge on the edge of the mask.
    Hope this helps,
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
  • Alfred Hammer
    July 19, 2011 at 5:24 pm
    Great, that really did help. Thanks a bunch!
