Activity › Forums › Adobe After Effects › Adding Alpha Channels
Posted by Cjfilm on April 3, 2006 at 10:41 pmI’m a new AE user (working on 6.0 with a G4 1.33 GHZ powerbook) can anyone tell me how to add an Alpha Channel to a comp
Michael Duff replied 20 years, 5 months ago 3 Members · 2 Replies -
Tim Kurkoski
April 4, 2006 at 5:24 pmAlpha is kind of automatic in AE. There are many different ways of making parts of your layer transparent, so it really depends on what you want to do with the layer. You can:
* Draw a mask
* Use a blending mode
* Use a track matte
* Use a keying effectYou can look up any of those in the help files. But if you want to be more specific as to what you want to do with your layer, I’m sure we can give you a more specific answer.
Michael Duff
April 4, 2006 at 11:41 pmtest your alpha by clicking on the little white square at the bottom of your comp window (next to the red/green/blue little squares). Or set your background colour to something like hotpink so you can see what will be transparent.
Make sure when you render that you set your export settings to include an alpha channel, or RGB+A, or 32bit. Rendering as a TGA sequence is a pretty safe format that most NLE’s will be able to read the alpha. Otherwise quicktime animation codec or AVI uncompressed are good too.
Cheers
Michael Duff –
Southern Cross Ten, Australia
