Activity › Forums › Adobe After Effects › Adding alot of data
  • Adding alot of data
    Posted by Tim Andrews on September 22, 2009 at 8:06 pm
    (Forgive me if I use any wrong terminology. I am still learning).
    I have alot of data (hundreds of frame numbers and values) which I would like to load into AE to be used as keyframe data.
    I can currently use a text editor to add the appropriate header and footer texts to my data, load the combined text into Windows clipbard; then paste the values into a Property for a Layer in the Timeline.
    This is efficient for one set of data, but I want to load many (perhaps several dozen) such sets of data.
    However, I see that this clipboard Pasteing system only permits a Paste to occur on multiple Properties in the same Layer.
    My questions are:
    1) Is there a better way of inporting such data?
    2) Does AE allows Layers to add multiple User defined Properties?
    Many thanks in advance for any suggestions of comments.
    Tim Andrews replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
