Activity Forums Maxon Cinema 4D Adding AFX-style expression slider controls for animating gradients in shaders
  • Adding AFX-style expression slider controls for animating gradients in shaders
    Posted by Matthew Ingram on August 20, 2020 at 10:31 am
    Would anyone be able to give me a quick summary as to how to do this?
    Is it a basic Xpresso thing?
    Thank you.
    Brian Jones replied 6 years, 1 month ago 2 Members · 2 Replies
  • Matthew Ingram
    August 20, 2020 at 12:47 pm
    ok figured this out:
    – add a null
    – put an expresso tag on it
    – add 4x user data entries to the null (0-100)
    – drop the null into the expresso tag and turn on the user data at the bottom
    – drag the icon of the transparency gradient of a standard shader into the xpresso window (couldnt get this to work with arnold)
    – connect the four user data entries to the material tag in expresso (shader properties>gradient>know position)
  • Brian Jones
    August 20, 2020 at 6:50 pm
    you can directly use a gradient in User Data (it’s one of the Data Types) and that can be plugged directly into a gradient in a material
