Activity Forums Adobe Premiere Pro Adding AE creations into Adobe Premiere 1.5
  • Adding AE creations into Adobe Premiere 1.5
    Posted by Christopher on June 13, 2005 at 5:04 pm
    I recently created some titles in AE and every time I try to import them into
    Premeire , I receive a error message stating that the file is not compatible. Can anyone assist me.
    New AE user
    Marcelo Lewin replied 21 years, 3 months ago 3 Members · 2 Replies
  • Mike Velte
    June 14, 2005 at 11:25 am
    What compressor did you select in Output Module>Format Options?
  • Marcelo Lewin
    June 15, 2005 at 3:41 pm
    You can not import AE comps into Premiere Pro. You have to render them as either AVI, or still images. If you output as AVI, then you should be ok importing it into PPro. I wished we could import comps directly, but can’t do that now. You can, however, import Sequences into AE, though they are limited as to what does transfer over.
    Cheers!
    Marcelo Lewin
    marcelo@thedailyfarce.com
    https://www.thedailyfarce.com/
