Activity Forums Adobe After Effects Expressions Adding a [x, y, z] value to an [x, y] value
  • Adding a [x, y, z] value to an [x, y] value
    Posted by Jay Brown on May 27, 2016 at 9:14 pm
    Is there an easy way to add an [x, y, z] value to an [x, y] value?
    You get the error “result must be of dimension 2, not 3”. Is there a way to check the length of the property so that only the [x] and [y]s are added together and the [z] is ignored?
    I can’t seem to figure out an easy way to do this.
    -Jay
    Jay Brown replied 10 years, 3 months ago 2 Members · 4 Replies
  • Dan Ebberts
    May 27, 2016 at 9:55 pm
    Something like this:
    a = [100,100];
    b = [100,100,100];
    a + [b[0],b[1]]
    Dan
  • Jay Brown
    May 27, 2016 at 10:33 pm
    Thanks for the response Dan!
    Sorry I should have fully explained what I’m trying to do. I have a 3D Point controller on a Null and I’m trying to create an expression that works universally for whatever property I add it too. For example the 3D Point values are [25, 50, 100].
    If I add it to rotation the value would be [25]. If I add to the scale it the value would be [25, 50]. If I add it too a 3D point the value would be [25, 50, 100] and so on.
    This is what I started with:
    oSet = thisComp.layer("Controller").effect("Offset")("3D Point");
    value + oSet;
    Is there a way to tell the property to ignore the extra value?
  • Dan Ebberts
    May 27, 2016 at 10:55 pm
    I think this works:
    if (value instanceof Array){
    if (value.length == 2){
    value + [oSet[0],oSet[1]];
    }else{
    value + oSet;
    }else{
    value + oSet[0];
    Dan
  • Jay Brown
    May 27, 2016 at 11:02 pm
    It works like a charm! You are an absolute legend!
    Originally I tried .length and length() on oSet and kept getting errors, I didn’t even think about trying it on the value itself. I finally get now too how the (value instanceof Array) works!
    thank you so much,
    -Jay
