Activity › Forums › Adobe After Effects › Adding a waving motion to a group of distributed layers
  • Adding a waving motion to a group of distributed layers
    Posted by Kurt Johnson on January 19, 2012 at 2:36 pm
    Howdy folks – what do you suppose would be the easiest way to achieve this:
    I have about 50 identically sized images that I will distribute in a grid formation across the screen. I’d like to generate a subtle waving motion across the entire grid, like a gentle flag waving without distorting the images themselves, which is to say, like a row of people in a stadium doing “the wave”, progressively adjusting the Z position forward then back.
    Thanks for any help!
    Kurt
    Kurt Johnson replied 14 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Blacker
    January 19, 2012 at 3:55 pm
    Animate them all at the same time with the movement you want, then offset the keyframes using sequence layers, perhaps?
    http://www.stephenblacker.com
  • Avrohom Kohn
    January 19, 2012 at 5:50 pm
    Trapcode has a plugin called Echospace which does just that: it lets you set repeat motions and distribute layers in any direction. I know you have to pay some money for it but I thought it’s worth a mention. I set up a shot that required hundreds of layers offset in 3D space. So I used Echospace to replicate my layer, than, using the option button while dragging an identically-sized layer to the new copies, I was able to set up a complex animation with ease. Here’s the video I’m talking about: https://www.youtube.com/watch?v=uga4ei-gfDo You will see the 3D layers about half way through.
    Avrohom
  • Kurt Johnson
    January 19, 2012 at 9:22 pm
    Thanks for the replies, folks – I have access to Echospace, so it seems like that will be the way to go. I’ll head in that direction first. Thanks!
    Kurt
  • Michael Szalapski
    January 20, 2012 at 2:37 pm
    There’s also this very cool tutorial [link].
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kurt Johnson
    January 20, 2012 at 8:57 pm
    Michael, thank you so much for this. This is the approach I’ve settled on. I tried the Echospace thing – easy to replicate the grid, not easy to generate a fluid waving motion in the manner I wanted. But this tutorial came as close as I needed to get. Thanks again!
    Kurt
  • Michael Szalapski
    January 20, 2012 at 9:38 pm
    No problem. I love this sort of solution. It’s so beautifully elegant.
    – The Great Szalam
  • Kurt Johnson
    January 20, 2012 at 9:43 pm
    Oh sure, me too, but it’s so far over my head it’s almost below again. I’d have better luck trying to sequence my own DNA than i would coming up with something like this. And that’s really the nature of this stuff. Whole lotta standing on shoulders going on…
