Activity Forums Adobe Audition Adding a “thump” or a “big bang”
  • Adding a “thump” or a “big bang”
    Posted by Jonathan Reed on April 16, 2020 at 1:37 am
    I’m working on adding sound effects to a teleportation scene. I’m having trouble with the electric “zap” sound effect make a deep bass sound. I’ve looked up online and all i’m finding is how to add bass to music which isn’t getting the effect i’m looking for.
    Can I get any help please.
    P.S. Am I making sense?
    Chris Wright replied 6 years, 3 months ago 3 Members · 2 Replies
  • Rob Neidig
    April 16, 2020 at 5:18 pm
    Many times the best sound effects are a combination of several different effects mixed together. Particularly when it comes to science fiction effects as you are trying to create something that does not currently exist in nature.
    For your teleportation, you might try mixing the zap sound you have with a low rumble or low drone sound. You will need to play with how much of each to mix and when to fade in and out of a particular effect.
    I assume you’re trying to add bass to your zap sound through boosting the lower frequencies with EQ. That isn’t working for you because all EQ can do is boost the bass that’s already there in the sound. It can’t “add” bass that isn’t already present. So mixing in an effect that has bass in it is your best bet.
    Have fun!
    Rob
    Rob Neidig
    R&R Media Productions
    Eugene, Oregon
  • Chris Wright
    May 3, 2020 at 9:15 pm
    this isn’t so much an audition thing as it is an effects process. i’d look at some 3rd party plugins unless you can record pure organic components from scratch and layer them.
