Activity › Forums › Boris FX Particle Illusion › Adding a text file to PI – from Truespace2PI
  • Adding a text file to PI – from Truespace2PI
    Posted by David Del on May 7, 2008 at 6:51 pm
    I have a TEXT file from the exporter – Position exporter to PI…so how do I import the text file (position data) into PI? After this is done, how do I take that info back into my 3d program?
    David Del replied 18 years, 5 months ago 2 Members · 2 Replies
  • Alan Lorence
    May 7, 2008 at 9:06 pm
    R-click on the emitter in the hierarchy (after adding to the stage) and “import – position data”.
    There’s no export back to 3D — you render the particles with an alpha channel for compositing back on your 3D render.
    Alan.
    http://www.wondertouch.com
  • David Del
    May 7, 2008 at 9:24 pm
    Ok, I guess that is not going to work in the way I had it set up presently.
    Alan, I have a 3D camera running around a scene (3D space), but the place where I want the PI to composite is not moving (the camera is moving). When I export the data, it is the same number for each of the 400 frames because only the camera moves…so I am not sure how to proceed from here. Any suggestions?
