Activity Forums Apple Motion Adding a stroke/outline to masked text
  • Adding a stroke/outline to masked text
    Posted by Chris Bentley on March 17, 2010 at 2:51 pm
    I’m using Apple Motion 4 and have a block of text added to an image mask layer so that the video plays through the text.
    I would like the text to have a stroke on it, but have been unsuccessful in accomplishing this. When I add a stroke through the Text Style –> Outline, the stroke is included in the mask and is transparent – not a solid stroke.
    I’ve tried accomplishing this using an object oriented mask via the underlying video as well as simply changing the blend mode to Stencil Alpha on the text — both result in the stroke/outline being added into the mask.
    Any suggestions?
    Chris
    Bret Williams replied 10 years, 1 month ago 4 Members · 4 Replies
  • Mark Spencer
    March 17, 2010 at 3:27 pm
    Duplicate the text layer, create the outline on the duplicate, and place that layer on top.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Chris Bentley
    March 17, 2010 at 4:09 pm
    While waiting for my post to be approved, I did just that. Worked like a charm!
    Thanks, Mark!
  • Tim Allen
    January 31, 2011 at 5:35 pm
    How could I accomplish this outline effect with a keyed out element, or anything else that has alpha data?
    The Real Tim Allen
    Tribal Iris | HD Production & Finishing
  • Bret Williams
    July 21, 2016 at 8:37 pm
    I needed this and am replying 5 years too late. Easiest I’ve found is to just add an outer glow with inner and outer color the same, and set range to 0. A radius of 4 or 5 seems to eliminate the tiny soft edge, and will allow you to double up the effect as many times as needed to get the thickness needed.
