Activity › Forums › Adobe After Effects › adding a stroke to an object
  • adding a stroke to an object
    Posted by Eric Smith on August 25, 2009 at 9:35 pm
    Hello- I’m trying to add a stroke to a comp and not being able to achieve the effect i want. I have a comp with animated objects inside and i want to add a stroke to the comp and have it on the outside of the objects with sharp corners.
    I’ve tried to add a layer style and it works but has rounded corners when i align the stroke to the inside of the objects it gives me the sharp corners i want but takes to much away from the graphic so i need to keep it on the outside.
    I’ve tried a simple choker as well and get the same round corners.
    any thoughts?
    thanks -eric
    Jason Haberman replied 16 years, 6 months ago 4 Members · 4 Replies
  • Eric Smith
    August 26, 2009 at 3:00 am
    thats what i thought. ugh. thanks for your help i appreciate it. it just seems like this should be an easy one.
    cheers – eric
  • Todd Kopriva
    August 26, 2009 at 4:38 am
    You could use a shape layer to provide the stroke. Shape layer strokes have a miter join option, which gives sharp corners.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Larry S. evans ii
    August 26, 2009 at 3:19 pm
    You might also consider creating solid layer of the desired color, then cloning your graphic layer and using it as an alpha matte for the solid which would be “under” the original graphic layer.
    In theory if you then scaled up the cloned graphic, it would expose an even amount of the solid layer and produce a stroke-like edge around the entire graphic matching the original’s edges.
    This presumes you looking at having the stroke be static, but I think you might also be able to animate it using a mask and the mask shape parameter.
    Larry S. Evans II
    Executive Producer
    Digital I Productions
  • Jason Haberman
    March 13, 2010 at 10:08 am
    there is a way to do it. you were on the right path with the simple choke. You need to add a drop shadow before the simple choke on the object you are looking to outer stroke
