Activity Forums VEGAS Pro Adding a simple frames into sony vegas
  • Adding a simple frames into sony vegas
    Posted by Daniel Ontálek on July 5, 2015 at 8:28 pm
    Hi, i am 15 age beginner with sony vegas and i have horrible problem.
    I draw few frames in photoshop and i wanted to animate them but when i tried to put one frame into video track.. it mades the frame to stay few seconds long. but i want to put there only simple frame that begins on postion in timeline where i put it and finishes when i put to timeline another frame.
    For example here is a photo how it looks when i click open to put 3 frames in a row:
    John Rofrano replied 11 years, 2 months ago 3 Members · 4 Replies
  • Shawn Bossick
    July 6, 2015 at 12:22 am
    Hello!
    Vegas imports still images by default to 5 seconds, however this can be changed to any value you’d like.
    Open your preview window in Vegas. Right click in the preview window area. Select preview device preferences. Choose & click the editing tab. Change the new still image length (seconds) to your preference. For example, if you want your still image to be only 1 frame in length, adjust the value to 0.050
    Enjoy!
  • John Rofrano
    July 6, 2015 at 1:00 am
    I see that you images are numbered 01, 02, 03. This is good. You should load your images as an Image Sequence. Use File | Import | Media… and then select just the first image and click the box at the bottom that says Stills: [x] Open Sequence. The next window will ask you what frame rate you want to use. For example, if you want each image to be on the screen for 1/2 second select a frame rate 2 fps.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Daniel Ontálek
    July 6, 2015 at 8:01 am
    Thank you very much, both ways worked … 🙂 And 1 more question.. Please how can i make some covering effect to frames.. i don´t know how to explain it but i don´t want it simple frame skip to frame but i want to add some transition between the frames.
  • John Rofrano
    July 6, 2015 at 10:54 am
    [Daniel Ontálek] “Please how can i make some covering effect to frames.. i don´t know how to explain it but i don´t want it simple frame skip to frame but i want to add some transition between the frames.”
    If you want to make transitions between individual images you can use Options | Preferences | Editing and check “[X] Automatically overlap multiple selected media when added” and set the “Cut-to-overlap conversion (seconds)” to a reasonable setting based on how long you made each image. You will need to make each image at least 3 frames so that you can overlap one frame on each side.
    If you want to do this do not use the Image Sequence method that I showed you because you need to have individual image events on the timeline in order to overlap them.
    ~jr
