Activity Forums Adobe After Effects Expressions Adding a shape to shape layer
  • Dan Ebberts
    October 14, 2012 at 8:21 pm
    Try this:
    var shapeLayer = currentComp.layers.addShape();
    var shapeLayerContents = shapeLayer.property(“Contents”);
    var shapeGroup = shapeLayerContents.addProperty(“ADBE Vector Group”);
    var ellipse = shapeGroup.property(“Contents”).addProperty(“ADBE Vector Shape – Ellipse”);
    Dan
  • Sébastien Lavoie
    October 14, 2012 at 8:38 pm
    Excellent! This works perfectly, thanks a lot!
  • Hugo Tait
    December 27, 2013 at 12:24 pm
    I’ve got my script to add the shape vectors in a shape layer but I can’t find out how to get it to add a fill. can you point me in the right direction?
  • Dan Ebberts
    December 27, 2013 at 6:34 pm
    From your shape layer, assuming you have already added the “ADBE Vector Group” and the “ADBE Vectors Group” properties, it should look like this:
    myShapeLayer.property(“ADBE Root Vectors Group”).property(“ADBE Vector Group”).property(“ADBE Vectors Group”).addProperty(“ADBE Vector Graphic – Fill”);
    Dan
  • Sébastien Lavoie
    December 27, 2013 at 6:39 pm
    You will want to use the .addProperty("ADBE Vector Graphic - Fill") method. As in…
    var shapeGroup                = shapeLayer.property("Contents").addProperty("ADBE Vector Group");
    var fill = shapeGroup.property("Contents").addProperty("ADBE Vector Graphic - Fill")
