Activity Forums Adobe Premiere Pro Adding a sequence to the project window?
  • Adding a sequence to the project window?
    Posted by Steve Voltmer on June 7, 2013 at 6:30 pm
    I have a sequence in which I had to sync the audio track to the video, and now that I have the 2 synced is there a way to make a new clip from my sequence? I would like to take several clips from this sequence and use them for a new sequence without cutting up the larger synced sequence. I hope I explained this ok.
    Ann Bens replied 13 years, 3 months ago 3 Members · 2 Replies
  • Chris Tompkins
    June 7, 2013 at 8:03 pm
    select all the clips you want and copy them.
    Open new sequence and paste.
    Chris
  • Ann Bens
    June 7, 2013 at 8:14 pm
    Or select the synced piece, right click and nest.
    Drag this nest into the Source Monitor where you can cut several clips from and drop them in a new timeline.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
