Activity › Forums › Apple Final Cut Pro › Adding a pulsing red dot to a map
Posted by Dan Wiseman on June 28, 2013 at 12:14 pmHi all. I want to add a pulsing red dot to a map to guide people to certain locations along a river. Is there a way to do this in FCPX please? Thank you
Dan Wiseman replied 13 years, 2 months ago 5 Members · 5 Replies -
Jeremy Garchow
June 28, 2013 at 3:22 pm -
Michael Sanders
June 28, 2013 at 8:43 pmMotion? Pulse the opacity and then loop it.
Michael Sanders
London Based DP/Editor -
Jeff Kirkland
June 28, 2013 at 9:47 pmIf its just a single dot you could even just key frame opacity and position in FCPX. It’d only take a couple of minutes to create a repeating pulsing dot compound clip and then you could move that around the map.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland -
Bret Williams
June 29, 2013 at 4:26 amI don’t think I’d Keyframe it. I’d make one dot that fades in and out with a dissolve. Copy it. Ten paste it a zillion times. All in a compound as mentioned.
