Activity Forums Apple Final Cut Pro Legacy Adding a new ending without recompressing
  • Adding a new ending without recompressing
    Posted by Will Macneil on August 28, 2007 at 8:45 am
    Hi, I just want to make sure I’m doing this in the ‘cleanest’ way possible.
    I’ve got a DV Quicktime file of a feature film. This is the highest quality it currently exists in. I need to change the end credits and create a new seemless quicktime in DV.
    If I simply import the existing DV file, lay it into a dv timeline, tag on the new credits and output as a new DV quicktime, will the file be recompressed?
    Is there a better way to do this?
    Will
    Will Macneil replied 19 years ago 2 Members · 3 Replies
  • Will Macneil
    August 28, 2007 at 10:31 am
    !UPDATE!
    Sorry the source file is Photo JPEG 75% and should be output this way too! Same issues apply, I think.
    W
  • Jerry Hofmann
    August 28, 2007 at 11:12 am
    If you choose file/export/Quicktime Movie in the end to deliver the file back, it will not be recompressed unless you change formats.
    Sequence settings will also have to match the source material’s properties. Rendering equals recompression, but a file export done as I pointed out above, will not recompress the video.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Will Macneil
    August 28, 2007 at 1:18 pm
    Thanks Jerry, I thought this was the case, but just wanted to be certain.
    W
