Activity Forums Apple Final Cut Pro Legacy Adding a lower thirds logo without rendering it
  • Adding a lower thirds logo without rendering it
    Posted by Eric Beaton on November 12, 2008 at 9:17 pm
    At my work we usually have 45 minute videos and we want to put a little logo on the bottom right corner of the entire video. Can this be done without having to render out the whole video? I know in Adobe Premier if the pixel size of the overlaid image is the same as the sequence it wont need to render out. Does it work the same in Final Cut Pro?
    Richard Sanchez replied 17 years, 10 months ago 3 Members · 2 Replies
  • David Bogie
    November 12, 2008 at 9:26 pm
    Depends on your hardware capabilities and the codecs you are using but usually am alpha-based effect must be rendered. To not render puts much at risk.
    bogiesan
  • Richard Sanchez
    November 12, 2008 at 9:47 pm
    If you’re using a Kona 3 to layback to tape, you can use the downstream keyer for this. If not, you can use the watermark feature in compressor to add it as you compress. Otherwise, as David said, if you’re doing it within Final Cut, it will require a render.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
