Activity › Forums › JVC Cameras › Adding a HDD or SSD for use with my JVC-GY250.
  • Adding a HDD or SSD for use with my JVC-GY250.
    Posted by Tedd Kidd on February 14, 2012 at 3:22 pm
    Anyone have thoughts or suggestions on what kind of portable field recorder I could add for my JVC-GY 250?
    Tedd
    Paul Lewis replied 14 years, 7 months ago 2 Members · 1 Reply
  • Paul Lewis
    February 21, 2012 at 6:31 am
    Hi Tedd,
    I have a JVC GY-HD200, I am using a Datavideo DN-60, runs around $580.
    It records to a Compact Flash card, using the firewire interface.
    I can double master to both the DN-60 and tape,
    so far haven’t needed the tape, the files work fine with Avid Media Composer.
    Since you have a 250, you can use a recorder that uses the HD-SDI out,
    like the Blackmagic Design Hyperdeck Shuttle, just under $400, plus you
    need to get a suitable SSD drive.
    The Atomos Samuri has it’s own video screen, it’s $1,600.
    File based acquisition is so much better!
    Cheers,
    Paul Lewis
