Activity Forums Adobe Premiere Pro adding a dissolve to top n tail of clip
  • adding a dissolve to top n tail of clip
    Posted by Peter Groom on November 22, 2020 at 9:00 pm
    Hi – if i select a clip and hit d, premiere adds a dissolve (default length) to the front and end of the clip. BUT if i use the same technique to an audio clip it does nothing?
    Is there a different shortcut for audio dissolves or how can i create one?
    Thanks for aid
    Peter
    Stephen Eckelberry replied 5 years, 9 months ago 2 Members · 1 Reply
  • Stephen Eckelberry
    November 22, 2020 at 11:58 pm
    First, go to Preferences>Timeline “Audio transition default duration” and set how long you want your audio transition.
    Then go to your Effects tab>Audio Transitions>Crossfade and pick one of the transitions, “Constant Power” is default and works fine, then right click and “Set Selected as Default Transition”
