Activity Forums Apple Final Cut Pro Legacy Adding a dissolve over every cut in a photo show
  • Adding a dissolve over every cut in a photo show
    Posted by Forrest Love on January 26, 2009 at 8:28 pm
    I know this is a simple question. I’m adding a chapter to my sisters wedding DVD which is basically a slideshow with 200+ pictures which needs 200 dissolves. What is the best/most efficient way to do this?
    Jamie Pickell replied 17 years, 8 months ago 5 Members · 5 Replies
  • Rob Grauert
    January 26, 2009 at 8:49 pm
    I don’t think it is possible to select all the cuts and add a dissolve to all of them at once. I think the best thing to do is:
    Go the “Effects” tab (not the effects menu). Open the “Video Transitions” folder. Choose “Cross Dissolve.” Change “Length” to the desired amount. Select “Cross Dissolve.” Right Click>Set Default Transition.
    Go to the timeline. Select a cut>right click>add transition ‘cross dissolve’
    Unfortunately you can only do one cut at a time, but at least all you have to do is right click on it. I feel this is the fast way, but maybe someone knows of a faster way that I haven’t discovered yet.
    Robert J. Grauert, Jr.
  • Mike Johnson
    January 26, 2009 at 9:09 pm
    To save time, you can use cmd-T instead of going through the right click menu each time.
    Mike Johnson
    Final Cut Pro Editor
    Drury Outdoors
    http://www.druryoutdoors.com
    View Mike Johnson's profile on LinkedIn
  • Mike Johnson
    January 26, 2009 at 9:14 pm
    Oh, and just wanted to note that you don’t actually have to click on the edit. Your playhead just has to be aligned to the edit for the add default transition to work. Use the up and down arrow keys to navigate between edits. If you have good rhythm you could get through it pretty quick.
    Mike Johnson
    Drury Outdoors
  • Ken Summerall
    January 26, 2009 at 9:41 pm
    I think that you can do this to the entire timeline. Try this…
    1. Set your default transition.
    2. Select every clip in your timeline.
    3. Drag the selection to the canvas and drop onto the “overwrite with transition” overlay
    done!
    K
  • Jamie Pickell
    January 26, 2009 at 10:08 pm
    The other option is to use iPhoto to do the slideshow for you. Each picture will be the same length and you can set the dissolve as the transition.
    I’m doing this right now on over 800 family photos that my mother wants on a DVD. There was no way I was going to edit that many photos in FCP!
    Cheers,
    Jamie
