Activity Forums Maxon Cinema 4D Adding a displacement map to a shader
  • Adding a displacement map to a shader
    Posted by Guy Carmeli on September 13, 2009 at 1:23 pm
    Hello,
    I have created a model with the Danel shader for a steel look. I would like to add a displacement map, but the shader does not have the option.
    I have created a separate material with the displacement and have tried merging them in several ways, but to no avail.
    I’ve found a similar post but somehow the solution did not work for me; obviously I am doing something wrong, as I assume this is a rather simple task.
    I’d appreciate your help.
    Guy Carmeli replied 17 years ago 2 Members · 2 Replies
  • Brian Jones
    September 13, 2009 at 8:18 pm
    Danel is one of the old SLA shaders, I get weird results trying to mix a displacement shader with it as well. Try using Lumas in the color channel of a shader instead, Lumas is (I think) what became of Danel once the SLA shaders were absorbed. It’s very similar and with a bit of tweaking you should get what you want and you can use the displacement channel in the shader.
  • Guy Carmeli
    September 15, 2009 at 3:33 pm
    It took me a moment to figure that out, but it worked perfectly!
    Thanks very much!
