Activity Forums Adobe Premiere Pro adding a clock to a sequence
  • adding a clock to a sequence
    Posted by Jonny Webb on November 20, 2013 at 2:34 pm
    jeez I hope someone can help. ive reached the hairpulling point…
    In short, I have a sequence with a few video layers. The primary layer is a whole day edited down to 10minutes – lots of small clips on the timeline.
    I need to put a clock in the corner
    1) so, a new transparent video with a time code and cut it into lots of small pieces, calculate/guess the correct time and enter that as an offset – in each clip… That’ll take all day!! So obviously not.
    2) Add the timecode right on the first clip (cant crop it, so mask it?) apply look&feel, copy to next clip… Again ALL DAY METHOD
    So whats the right way (that gets the job done quickly)
    Thanks.
    ++ As we’re all here, i guess we’re not all there ++
    Chris Tompkins replied 12 years, 10 months ago 2 Members · 1 Reply
  • Chris Tompkins
    November 21, 2013 at 8:59 pm
    your transparent layer should be one clip spanning the entire sequence, not cut up.
    Apply effect to the transparent layer, Also, AE has more options for this.
    Chris
