Activity › Forums › Avid Media Composer › Adding a Client Monitor to my iMac
  • Adding a Client Monitor to my iMac
    Posted by Joseph Sierchio on May 18, 2020 at 1:33 am
    I’m currently running Media Composer 2019.12.0 and I have a 2017 27 inch iMac with a 4.2 GHz i7 processor, 40 Gigs of RAM and a Radeon Pro 580 Graphics card. I’d like to use my wall mounted TV as a client monitor through HDMI. Anyone know of a inexpensive solution?
    Joe
    Shane Ross replied 6 years, 4 months ago 3 Members · 2 Replies
  • Glenn Sakatch
    May 18, 2020 at 1:52 pm
    I would think a blackmagic mini monitor would work. Has sdi and hdmi out, and thunderbolt in.
    Not a mac person, so you may want to double check your available connections…but blackmagic should have something for your in the monitoring department.
    Glenn
  • Shane Ross
    May 18, 2020 at 5:38 pm
    You are right Glenn. The 2017 has a Thunderbolt 2 port (two, actually), so a Mini-Monitor is the perfect solution. TB to the Mini…then HDMI out to the TV.
    NOTE!!!
    Anytime you have an output device like that connected…be it a Mini monitor or an Avid box (DNxIO or Mojo)…audio gets routed to that box. So if you are monitoring audio from the iMac to a mixer, that will get cut off. You’ll need to either monitor from the TV, or get an HDMI splitter that will do HDMI out and also a separate audio only output… something like this:
    https://www.amazon.com/iArkPower-Extractor-Splitter-Optical-Supports/dp/B01I9JG70A
    Shane
    Little Frog Post
