Activity Forums Adobe After Effects Expressions Adding a clamp to sourceRectAtTime?
  • Adding a clamp to sourceRectAtTime?
    Posted by Quest Rogers on May 25, 2023 at 5:09 pm
    Hello,
    I have a lower third template in which I want to clamp the Y value of the “Size” property of a Rectangle Path on a shape layer. I want this shape layer to ignore scaling in “Size” Y beyond a certain value as it and the text animates on/off. The text gets quite all then scales down as it animates but I don’t want the box behind it to scale beyond a certain value. I’m having trouble figuring out how to incorporate a clamp or something similar into the expression I’m using below. If anyone has any tips on how to add a clamp to this I’d appreciate it!
    h = thisComp.layer(“NAME”).sourceRectAtTime(time,false).height;
    w = thisComp.layer(“NAME”).sourceRectAtTime(time,false).width;
    [w,h]
    Quest Rogers replied 3 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 25, 2023 at 6:47 pm
    Something like this maybe:
    minH = 10;
    h = thisComp.layer("NAME").sourceRectAtTime(time,false).height;
    w = thisComp.layer("NAME").sourceRectAtTime(time,false).width;
    [w,Math.max(h,minH)]
  • Quest Rogers
    May 25, 2023 at 9:33 pm
    Thanks Dan! I’ll give this a try.
