Activity › Forums › Adobe After Effects › Adding a CC to multiple Pre-Comps
  • Adding a CC to multiple Pre-Comps
    Posted by Jason Mcgovern on November 7, 2013 at 3:52 pm
    So I’ve gone a bit Pre-Comp crazy and now have multiple levels of pre-comps in my proj.
    How can I add a curves adjustment layer to each Pre-Comp and control that curves from one location so that it affects all instances in all Precomps?
    Todd Kopriva replied 12 years, 10 months ago 2 Members · 1 Reply
  • Todd Kopriva
    November 7, 2013 at 11:56 pm
    Are you using After Effects CC (12.1)? If so, you could use the property links feature to create one master Curves effect, copy it with property links, and paste instances onto the various precompositions. Or, very similarly, you could put the Curves effect on an adjustment layer, copy the entire adjustment layer with property links, and then paste instances of that adjustment layer inside your precompositions.
    After Effects team blog
