Activity Forums Apple Final Cut Pro Legacy adding a border AFTER cropping?
  • adding a border AFTER cropping?
    Posted by J. Tad newberry on July 4, 2007 at 6:52 am
    after i crop a clip in the motion tab and then try to add a border around the cropped clip, the border only appears at the original edges and not on the crop edge(s). is there a workaround for this?
    J. Tad newberry replied 19 years, 2 months ago 3 Members · 3 Replies
  • Tom Wolsky
    July 4, 2007 at 7:36 am
    Put a color matte underneath the image and crop to a slightly larger size than the image above it. Or use a third party filter. CGM Online has one.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Tom Meegan
    July 4, 2007 at 2:33 pm
    If you need the border to move with the image, nest the color matte Tom mentions above with the footage.
    To make the nest, select both layers and then hit Option-C. Name it appropriately.
    Option double click the nest in the time line to load it into the viewer, then use the motion tab to move the nest around.
    Happy Independence Day!
    The Other Tom
  • J. Tad newberry
    July 6, 2007 at 12:16 am
    Hi Two Toms!
    actually, i found a good workaround. i only needed the border to appear on one side of the cropped image, so i added a shadow via the motion tab. made it opaque, black, and no softness. it looks like a border!
    but thanks for the other options as well…
