Activity Forums Avid Media Composer adding 4×3 footage to 16×9 timeline
  • adding 4×3 footage to 16×9 timeline
    Posted by Dan O’brien on June 24, 2005 at 6:36 pm
    I have a 16×9 timeline, and I need to place 4×3 footage into it, with the beautiful “curtains” on either side of the picture to fill in the rest of the screen.
    How do I keep the 4×3 footage its original dimensions. Every time I edit the footage in, it stretches it. I’ve tried pan and scan with no luck.
    Any help would be appreciated.
    Dan O’Brien
    editing on Symphony pc.
    Michael Phillips replied 21 years, 2 months ago 2 Members · 1 Reply
  • Michael Phillips
    June 24, 2005 at 8:46 pm
    You need to add from the reformat section the 4:3 sidebars. It will keep the full 4:3 source aspect ratio inside the 1:9 anamorphic video. Using the Pan & Scan effect will allow you to do a tilt and scan where you need to crop the 16:9 from the 4:3 by moving the frame up and down on the original image. This will create a 16:9 anamorphic from the 4:3 source.
    Michael
