Activity Forums Adobe After Effects Adding 3D object in a footage
  • Adding 3D object in a footage
    Posted by Omer Aydin on August 4, 2009 at 11:50 am
    Hi people,
    I have a footage where I need to add in a Poser object.
    The camera is not still and I have tracked the scene using PFTrack and exported the solved camera motion data.
    First I tried importing both camera data and alpha keyed footage of the Poser object into AfterFX. It tracked fine but it didn’t look good with no perspective as camera moved.
    Then I tried to import camera data and background footage into Poser to have the 3D object keeps it’s perspective as camera moves, unfortunately I couldn’t find a way to import camera data into Poser 6.
    I’d be very happy to hear your suggestions to solve this. Thanks in advance.
    Gary Walker replied 17 years ago 2 Members · 1 Reply
  • Gary Walker
    September 22, 2009 at 12:05 pm
    Im not sure about Poser, but with other 3d packages you can use Voodoo Camera tracker quite successfully:
    https://www.digilab.uni-hannover.de/docs/manual.html
    Maybe have a quick look on YouTube, there are some examples of using Voodoo, and also a few tutorials on how to get footage in. I primarily use Blender, but Im sure there will be a work-around somewhere along this route.
