Activity Forums Adobe Premiere Pro Adding 3:2 pulldown via hardware output in Premiere Pro??
  • Adding 3:2 pulldown via hardware output in Premiere Pro??
    Posted by Peter Price on June 3, 2014 at 6:25 am
    Hi all,
    As you remember in FCP 7, if you wanted to playback a 23.98 project to 29.97fps monitor, all you had to do, was go to the View menu and choose 1080i29.97 and then it just did the 3:2 pulldown automatically in hardware output.
    But I can’t seem to find this capability or option in Premiere Pro CC. Does anyone know how to do this, or is it not possible in Premiere Pro?
    Please advise. Thanks!!
    Chris Borjis replied 12 years, 3 months ago 3 Members · 2 Replies
  • Tero Ahlfors
    June 3, 2014 at 4:35 pm
    I believe that is a I/O specific feature that you’d enable on the I/O side.
  • Chris Borjis
    June 3, 2014 at 5:03 pm
    you can also copy your 23.976 sequence into a 29.97 sequence
    and premiere will do the pull down if your output card
    doesn’t support it.
