Activity › Forums › Adobe After Effects Expressions › Adding 100% ease to this expression
  • Adding 100% ease to this expression
    Posted by Chris Meadmore on November 29, 2018 at 12:41 pm
    Hi I’m using the below expression to control 2 keyframe positions on a simple A to B animation.
    Once the expression is added it became a linear move so I swapped ‘linear’ to ‘ease’ but how can I control the amount of ease and have it set to out 30% / in 100%
    Probably a simple fix but I’ve not done it before.
    if (numKeys > 1){
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = thisComp.layer("CONTROLS").effect("Position 01")("Slider");
    v2 = thisComp.layer("CONTROLS").effect("Position 02")("Slider");
    ease(time,t1,t2,v1,v2);
    }else
    value
    Filip Vandueren replied 7 years, 9 months ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    December 9, 2018 at 10:56 am
    Try adding .value after (“Slider”). Might be that easy.
    Senior Graphic Designer
  • Filip Vandueren
    December 9, 2018 at 2:23 pm
    Hi Chris,
    the expression ease() method only simulates Easy-easy, which is to say 0 speed at 33% influence, there is no way to change this.
    You would need to write your own method, look into cubic-bezier functions…
