Activity Forums Adobe After Effects Expressions Adding 00s to DAYS in a counter timer using format YEARS:DAYS:HOURS:MINUTES:SECONDS
  • Adding 00s to DAYS in a counter timer using format YEARS:DAYS:HOURS:MINUTES:SECONDS
    Posted by Simon Peller on August 15, 2020 at 12:36 am
    Hi everyone.
    Long time lurker. First time poster ☺
    Usually I can hash together an expression using what I can find online (mostly from this website tbh) but I’m having trouble with this particular one.
    I’m making a counter using the expression below. The time format I’m using is YEARS:DAYS:HOURS:MINUTES:SECONDS
    As you can see I’m using a function to add 0 to n if n is less than 10.
    This works fine for the 2 digit numbers (YEARS, HOURS, MINUTES, SECONDS) but not with the 3 digit number (DAYS).
    I would like to achieve YY:DDD:HH:MM:SS
    For example 01:009:23:59:59. Where the DAYS always has 3 digits whether its 001, 999 or anything in between.
    Thank you kindly for your help. I hope in the future, as I grow in confidence using expressions, I’ll be able to help someone else here in return.
    Much love and respect.
    Simon.
    slider = effect("Point Control")("Point")[0]
    sec = Math.floor(slider)%60;
    min = Math.floor(slider/60)%60;
    hour = Math.floor(slider/3600)%24;
    days = Math.floor(slider/86400)%365;
    years = Math.floor(slider/31536000);
    function addZero(n) {
    if (n < 10) return "0" + n else return n;
    addZero(years) + ":" + addZero(days) + ":" + addZero(hour) + ":" + addZero(min) + ":" + addZero(sec)
    Simon Peller replied 6 years ago 3 Members · 4 Replies
  • Chaz Chester
    August 15, 2020 at 1:46 am
    Like this?
    slider = effect(“Slider Control”)(“Slider”);
    if (n < 10) return “0” + n else return n;
    function addTwoZero(n) {
    if (n < 10) return “00” + n;
    if (n >= 10 && n < 100) return “0” + n;
    else return n;
    addZero(years) + “:” + addTwoZero(days) + “:” + addZero(hour) + “:” + addZero(min) + “:” + addZero(sec)
  • Filip Vandueren
    August 15, 2020 at 7:48 am
    A compact Javascript way to add leading zeroes is to always add more than you need, then slice the string length to what you need from the right like this:
    (“00″+days).slice(-3);
    and
    (“0″+months).slice(-2);
    This works if you’re sure days is never more than 3 digits, months never more than 2
    Because for example
    (“00″+123).slice(-2)
    would return 23, not 123
  • Simon Peller
    August 15, 2020 at 2:28 pm
    Wonderful. Perfect. Thank you.
    Not only has this solved my initial problem but by reverse engineering and tweaking your additional bit of code it has allowed me to solve a couple of other problems I was having trouble with in other projects.
    Really, thanks so much for taking the time to reply so quickly.
    Simon
  • Simon Peller
    August 15, 2020 at 2:37 pm
    Thank you for your swift reply.
    Unfortunately I don’t fully understand this due to my lack of Java knowledge. No doubt as I become more familiar with expressions and Java your reply will make a lot more sense ☺
    For now my problem was solved with the help of Chaz Chester in one of the replies above.
    Thanks again
    Simon
