Activity Forums Adobe After Effects Add work area to render queue, then select a new work area and add that to the queue as well and then set off batch
  • Add work area to render queue, then select a new work area and add that to the queue as well and then set off batch
    Posted by Jimmy See on May 11, 2018 at 1:25 am
    There’s going to be a separate post about why I want to do this but getting right to the nub of the problem, I want to know how to queue up sections of a composition for rendering, not the whole thing.
    I set the work area to the duration of a selected layer and add it to the render queue, but if I do that same action again, the new position of the work area becomes applicable to the items already in the queue meaning the same work area rendered out multiple times and all the previously selected work areas ignored.
    Roland R. kahlenberg replied 8 years, 3 months ago 4 Members · 3 Replies
  • Steve Bentley
    May 11, 2018 at 2:17 am
    If you select the render settings for each cued item you can change the time span settings to custom and then choose your render “area”.
  • Walter Soyka
    May 11, 2018 at 4:19 pm
    … or you could use a script to manage the render sections, and make the process more easily repeatable.
    I use Queue_Comp_Sections from Christopher Green’s Ae script collection (if it’s helpful to you, click the donate button and send him a token of your appreciation):
    https://www.crgreen.com/aescripts/
    Or you can get Queue Work Area from Aescripts:
    https://aescripts.com/queue-work-area/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Roland R. kahlenberg
    May 12, 2018 at 5:11 am
    Another option is to send the renders to AME.
    PathSlicer – Advanced AE Shape Layer Effect
    https://www.broadcastgems.com/pathSlicer
    – create highly customizable custom animated typefaces
    – create amazing transitions
    – create cool lower 3rds and panels
    – create burst effects
    Do it all on a single Shape layer with minimal keyframes.
    TypeGEMs – The Most Complete Type Tool Effect for AE
    https://www.broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    BorisFX mocha Certified Instructor
