Activity › Forums › VEGAS Pro › Add visible timecode to media problem in 10c
  • Add visible timecode to media problem in 10c
    Posted by Larry Brewer on January 16, 2011 at 5:30 am
    In Sony Vegas, the method I have always used to display the actual tape timecode in a window over the media for “client copies”, Is to use TOOLS/ SCRIPTING / ADD TIMECODE TO ALL MEDIA.
    But that doesn’t work anymore. Vegas update 10c will only show frame numbers. What gives? Am I missing something?
    So I reinstalled Vegas 10a and bingo! My timecode numbers came back.
    Went back to 10c and same thing… frame numbers.
    Is there a fix, workaround,
    Graham Bernard replied 15 years, 8 months ago 2 Members · 1 Reply
  • Graham Bernard
    January 16, 2011 at 8:26 am
    The Timecode Frames display has been reported as a bug. No workaround in 10c. If you’re ok going back to 10a then that would be your only “fix” at present.
    SONY will get it cured, I’m sure.
    Grazie
