Activity › Forums › Adobe Premiere Pro › Add Video Effect to Group of Clips or Track?
  • Add Video Effect to Group of Clips or Track?
    Posted by Brandon Adams on June 22, 2012 at 6:01 pm
    Is there any way to group clips so that I can apply an effect and have one single control that affects all of them? I believe you can do this to an audio track, but I’m hoping to do it with video.
    I’m basically looking for a better way to be able to apply effects to interviews with two cameras. Right now I apply an effect to the first clip_camA and copy it to the rest of the camA clips. But if I need to make an adjustment obviously that gets annoying. I have the A and B cams on different tracks.
    Any help would be appreciated. Thanks!
    -Brandon
    Gabriel Sanchez replied 14 years, 3 months ago 6 Members · 6 Replies
  • Bret Williams
    June 22, 2012 at 6:56 pm
    Add adjustment layer in cs6.
  • Kris Merkel
    June 22, 2012 at 7:16 pm
    If in 5.5 use dynamic link to do the vfx work in AE for the group of clips. It’s archaic but it works.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Specialist, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS 5.5
    FCP7 and Studio
    Blackmagic Design UltraStudio 3D
    AJA IO XT
    FSI LM-2340W
  • Kevin Monahan
    June 22, 2012 at 7:24 pm
    Or Nest the clips, and add the effect to the nest.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Brandon Adams
    June 22, 2012 at 10:19 pm
    Thanks for the feedback. Adjustment layers won’t work because that applies to everything under it, not to a single track, and I don’t want the same effect on every clip in the timeline.
    I’m not interesting in roundtripping to AE. PPRO works fine, just looking for some shortcutting within it.
    Nesting seems like it’s probably the best option. I’ll play around with that idea.
    -Brandon
  • Brad Tuitt
    June 23, 2012 at 10:16 pm
    your adjustment layer doesnt have to be over your whole track or every clip u can edit it to the length you need it to be over the clips you want to add the effect to
  • Gabriel Sanchez
    June 24, 2012 at 9:59 am
    2 ways:
    1- apply effects to one clip, then “copy” the clip, select all the clips where you want to paste the effects and “paste atributes”
    2- Nest the sequence into a new one and apply the effects to the nested seq.
    Regards
