Forums Adobe After Effects Expressions Add values to an empty array
  • Add values to an empty array
  • Padraic Rapp
    November 25, 2019 at 3:16 pm
    Hey ya’ll !
    I am trying to create a shape layer path based on a target layer’s position.
    this expression:
    createPath(points = myPoints, inTangents = [], outTangents = [], isClosed = false);
    lets me create a path based on an input array (“myPoints”).
    I want this array to be dynamic for a lack of a better term ( I am no programmer), i.e. I want to add values to this array and I thought I could use something like this:
    tCount = 0; // time counter
    tInter = 0.5; // time interval (samples)
    myPoints = []; //an empty array to store the path points
    while(tCount
    The first line in the while loop returns an error ("Undefined value used in expression"). I thought I could add values to an empty array but I guess I'm doing something wrong. Can somebody help me out with this? How DO you add values to an array? Or should I be generating a string inside the "myPoints" array that contains all the points based on a similar while loop?
    Any help is greatly appreciated!
  • Dan Ebberts
    November 25, 2019 at 5:00 pm
    The easiest way would be to use push(), like this:
    myPoints.push(thisComp.layer(“target”).transform.position.valueAtTime(tCount));
    Dan
  • Padraic Rapp
    November 26, 2019 at 7:41 am
    YES! works perfectly. Thank you so much Dan!
Viewing 1 - 3 of 3 posts
Log in to reply.
