Activity Forums Adobe After Effects Expressions Add two attributes, offset their ratios
  • Add two attributes, offset their ratios
    Posted by Jack Sewell on November 3, 2010 at 11:30 am
    Ok,
    I’ve got two attributes on Particular that I would like to animate together, i.e, using one slider / variable.
    I can pick-wip them together, so that when I move one, the other moves too. Good stuff!
    However, I’d like to offset the ratios. In other words, I’d like one to move at a power of 10, while the other moves normally. So when I move this .1, that one moves 1.
    The current expression looks like this on the effect size in the turbulent fields;
    effect(“Particular”)(“Octave Scale”)
    I know there’s the ‘*10’ expression, but I don’t know where to stick it…………
    ……if you’ll pardon the expression! 😉
    Many thanks
    Jack Sewell replied 15 years, 10 months ago 2 Members · 2 Replies
  • Kevin Camp
    November 3, 2010 at 3:45 pm
    so you have one octave scale pickwhipped to the other… and you’ve already figured it out.
    just and *10 to your expression, so it would look like this:
    effect("Particular")("Octave Scale")*10
    essentially it’s taking the value from the other octave scale and multiplying it 10.
    pretty simple, huh…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jack Sewell
    November 3, 2010 at 7:53 pm
    HA! Simple pie……that worked great Kevin, thanks for your help 🙂
