Activity Forums Adobe After Effects Expressions Add Trim Paths to any selected shape layers with a Script
  • Add Trim Paths to any selected shape layers with a Script
    Posted by Vincenzo Imbimbo on May 26, 2022 at 4:00 pm
    Hello guys, anyone can help me to add a Trim Paths to any selected shape layers? I just want to add ONE trim paths to each layer, no matter how many shapes it has inside.
    Any help?
    This is the property path to the Trim Paths:
    layers[i].property(“ADBE Root Vectors Group”).property(“ADBE Vector Filter – Trim”)
    I also want to access the “Start” and “End” of the trim paths to add an expression to each one.
    This is the property path for “Start”:
    layers[i].property(“ADBE Root Vectors Group”).property(“ADBE Vector Filter – Trim”).property(“ADBE Vector Trim Start”)
    And this is the property path for “End”:
    layers[i].property(“ADBE Root Vectors Group”).property(“ADBE Vector Filter – Trim”).property(“ADBE Vector Trim End”)
    I think the code should be something like this:
    var comp = app.project.activeItem;
    var layers = comp.selectedLayers;
    if(layers.length == 0){
    alert("You must select a layer");
    } else {
    for(var i = 0; i < layers.length; i++){
    layers[i].property("ADBE Root Vectors Group").//add??//property("ADBE Vector Filter - Trim")
    //and then://
    layers[i].property("ADBE Root Vectors Group").property("ADBE Vector Filter - Trim").property("ADBE Vector Trim Start").//expression = "my expression"??//
    Andrei Popa replied 4 years, 3 months ago 2 Members · 8 Replies
  • 8 Replies
  • Andrei Popa
    May 27, 2022 at 6:51 am
    I think this is what you need
    if (layers.length == 0) {
    } else {
    for (var i = 0; i < layers.length; i++) {
    if (layers[i] instanceof ShapeLayer) {
    var myTrim = layers[i].property("ADBE Root Vectors Group").addProperty("ADBE Vector Filter - Trim");
    //and then://
    myTrim("ADBE Vector Trim Start").expression = "value";
  • Vincenzo Imbimbo
    May 27, 2022 at 3:46 pm
    Thank you Andrei!! This is what i need it, but there’s a little problem, if i execute the script again it will add another Trim Paths to each selected layer, i just want to have 1 Trim Path, no matter how many times i execute the script, any way to fix this? Something like “if this shape layer already has a trim path then don’t add a trim paths”, thank you!
  • Andrei Popa
    May 27, 2022 at 4:49 pm
    I think this will be the fastest way
    } else {
    var myTrim = layers[i].property("ADBE Root Vectors Group")("ADBE Vector Filter - Trim")
    ? layers[i].property("ADBE Root Vectors Group")("ADBE Vector Filter - Trim")
    : layers[i].property("ADBE Root Vectors Group").addProperty("ADBE Vector Filter - Trim");
    //and then://
  • Vincenzo Imbimbo
    May 31, 2022 at 8:40 am
    Hi again Andrei, thank you for your reply, i tried the code but i’m getting a syntax error saying that “?” doesn’t have an assigned value. What i am missing?
  • Vincenzo Imbimbo
    May 31, 2022 at 8:57 am
    Oh nevermind, it was the “;” that i was keeping at the end of “var myTrim…” so the ternary operator was missing the condition, but now is working perfectly, thank you so much!!
  • Vincenzo Imbimbo
    May 31, 2022 at 9:06 am
    Is there any way to apply the same Ternary Operator to this line of code?
    var durationIn = myLayers[i].Effects.addProperty(“ADBE Slider Control”);
    durationIn.name = “IN”;
    I want to add to each selected layer a slider control named “IN” but if i run the script again i don’t want to add another slider control named “IN”, i just want to overwrite the value of that slider with a new input. Can you help me? Thanks again!
  • Vincenzo Imbimbo
    May 31, 2022 at 9:45 am
    I figured it out with this:
    var durationIn = myLayers[i].Effects("ADBE Slider Control")
    ? myLayers[i].Effects("ADBE Slider Control")
    : myLayers[i].Effects.addProperty("ADBE Slider Control");
    durationIn.name = "IN";
    var durationOut = myLayers[i].Effects("ADBE Slider Control")
    durationOut.name = "OUT";
    But the problem is that the ternary operator just read if the layer has a “Slider Control” and i need it to be specific with “IN” and “OUT” sliders. Sorry for asking so much questions, i’m really newbie with JS.
  • Andrei Popa
    May 31, 2022 at 2:01 pm
    You can use the name of the effect instead of its matchname if you want to. Like this:
    var durationIn = myLayers[i].Effects("IN")
    ? myLayers[i].Effects("IN")
    var durationOut = myLayers[i].Effects("OUT")
    ? myLayers[i].Effects("OUT")
