Activity › Forums › Adobe After Effects › Add to Render Que
  • Add to Render Que
    Posted by Mike Rawers on September 3, 2009 at 1:16 pm
    About a day ago every time I add a composition to the render queue the output to: defaults to somersault.ffx ?????
    And I can not change it to the name of my comp and the output module?
    has anyone else seen this issue? I don’t think I changed any preferences.
    Please Help thanks!
    Mike Rawers replied 17 years ago 30,073 Members · 2 Replies
  • Mike Rawers
    September 3, 2009 at 3:27 pm
    Normally I would say yes of course I did. And then pretend I knew how to do that. But unless I accidentally hit the shortcut for that process then no I was not trying to create a favorite.
    I did figure out that in the render queue if I click the output mode drop down and then got to Custom I can get the options I am use to seeing. But I prefer not to have to do this…
    Does that help at all?
  • Mike Rawers
    September 3, 2009 at 3:48 pm
    Bookmarked. THANKS! Yes somersault is a predefined effect. I am check the settings now. I will post my findings. Thanks for your help
