Activity › Forums › Adobe After Effects Expressions › Add the Animate Fill Color RGB to text layer
  • Add the Animate Fill Color RGB to text layer
    Posted by Jace Bradley on January 14, 2023 at 7:33 pm
    I am trying to create a script that add the Fill Color RGB to selected text layers.
    here is the code so far
    // Create a new window for the UI panel
    var myPanel = new Window(“palette”, “Add RGB Fill”, undefined);
    // Add a button to the panel
    var myButton = myPanel.add(“button”, undefined, “Add RGB Fill Color”);
    // Add an event listener to the button
    myButton.onClick = function() {
    // Get the active composition
    var activeComp = app.project.activeItem;
    if (!(activeComp instanceof CompItem)) {
    alert(“Please select a text layer in the active composition.”);
    return;
    // Get the selected text layers
    var selectedLayers = activeComp.selectedLayers;
    if (selectedLayers.length == 0) {
    alert(“Please select at least one text layer.”);
    return;
    for (var i = 0; i < selectedLayers.length; i++) {
    var textLayer = selectedLayers[i];
    if (!(textLayer instanceof TextLayer)) {
    alert(“Please select only text layers.”);
    return;
    // get the text path
    var PickColor = textLayer.property(“Text”);
    //after getting this path, how can I add the animate Fill Color RGB?
    // Show the UI panel
    myPanel.show();
    Any help?
    Jace Bradley replied 3 years, 8 months ago 3 Members · 5 Replies
  • Manuel Moellmann
    January 14, 2023 at 7:42 pm
  • Dan Ebberts
    January 14, 2023 at 7:45 pm
    I think this works:
    var myPanel = new Window("palette", "Add RGB Fill", undefined);
    var myButton = myPanel.add("button", undefined, "Add RGB Fill Color");
    alert("Please select a text layer in the active composition.");
    return;
    alert("Please select at least one text layer.");
    return;
    alert("Please select only text layers.");
    return;
    var animator = textLayer.property("ADBE Text Properties").property("ADBE Text Animators").addProperty("ADBE Text Animator");
    var fill = animator.property("ADBE Text Animator Properties").addProperty("ADBE Text Fill Color");
    myPanel.show();
  • Jace Bradley
    January 14, 2023 at 8:48 pm
    Thank you. That works but is not adding the range selector so I am able to animate the start and end
    I tremendously appreciate your help.
  • Dan Ebberts
    January 14, 2023 at 9:28 pm
    Good point. Change that section to this:
    var selector = animator.property("ADBE Text Selectors").addProperty("ADBE Text Selector");
  • Jace Bradley
    January 15, 2023 at 4:32 pm
    That worked ! 🙂 Thank you very much.
