Activity Forums Square Box CatDV Add stills to movieclip
  • Add stills to movieclip
    Posted by Everet Arlington on August 15, 2020 at 3:03 pm
    Hi, been looking at your website and playing around a bit with this MAM. Can I add stills of the pict of a filmposter to a movie clip in a catalog? Maybe a script?
    Eve
    Bryson Jones replied 6 years ago 2 Members · 1 Reply
  • Bryson Jones
    August 19, 2020 at 3:30 pm
    Everet,
    I’ll pitch in what I know and get some factory folks to add on what I miss.
    If you’re in the desktop app there are several options:
    You can delete the thumbs and recreate new ones.
    You can set a new “Poster Frame” which changes the default thumbnail.
    And you can set a marker which gives you a thumb per marker. (This will increase the size of your db of course.)
    There is also a new feature in Web3 called filmstrips (I believe) that makes a little hover and playback film of stills for a clip.
    Finally, via API you can inject thumbs for a clip in the server.
    Describe your use case a bit more and I’ll bet there’s a workable answer. Also, what continent are you on?
    bryson
    bryson “at” northshoreautomation.com
