Activity Forums Adobe After Effects Expressions Add shape ‘path’ keyframe at CTI
  • Add shape ‘path’ keyframe at CTI
    Posted by Gavin Edwards on June 13, 2019 at 9:57 pm
    Is there a script/let that can add a keyframe to the path property of a shape layer? I find myself wasting time drilling down and finding quickly the path property in order to select it and manipulate it, if a keyframe was easily accessible via the ‘U’ shortcut then I could access the property quickly and easily as I am often having to access paths.
    I believe one plugin has this feature as a single click button so I figure it must be possible. If it is then I could access the script quickly via a K-Bar button.
    Thanks in advance.
    Dmytro Korolkov replied 5 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tomas Bumbulevičius
    July 4, 2019 at 6:15 pm
    Hey Gavin, not sure whether you solved this or not. Assuming there are N shape paths in a single layer – do you want to select it in the project viewport, and expect ‘add keyframe’, to be able to reveal it with ‘U’?
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Gavin Edwards
    September 25, 2019 at 2:56 am
    Hi Tomas, thanks for your reply. If I understand you correctly, yes something similar to this.
    If I have a lot of shape layers that I want to animate directly the path, it would be good if there was a script that could create a keyframe on each path, so then I could press ‘U’ access them and manipulate them quicker. If I have to twirl down each shape layer to access the path property and a keyframe it takes time. Do you know if its possible to do something like this?
    September 25, 2019 at 12:48 pm
    Hey Gavin, while I am not sure whether such script already exists, I don’t see a problem in creating one. Basically, it would require simply looping through the contents of shape layer, and where paths are found – set a keyframe at current time!
    Find out more:
  • Gavin Edwards
    September 25, 2019 at 12:59 pm
    Hi Tom, yes the problem is, if I have 100 layers that I want to animate the paths for, I have to unfold 100 layers and add keyframes which takes some time – if only there was a keyboard shortcut (like ‘S’ for scale) that would just bring up the path property.
    Therefor, I was wondering if anyone knew of a quicker way, perhaps with a script that could instantly add a keyframe to every path property in each shape layer without the need for unfolding.
    Unfortunately my knowledge of scripting is zero, hence my shout out for assistance…
  • Diego Ferrero
    May 7, 2020 at 3:41 pm
    I’ve found a workaround for this… is not the best but works everytime.
    1 . Enable Auto-keyframe mode.
    2 . Select the shape layer on the composition panel
    3 . Use the Pen Tool to select and move the nodes or shapes you want to animate.
    That´s all… now you can press “u” on the keyboard and you´ll see only keyframed shapes.
  • Gavin Edwards
    May 8, 2020 at 12:42 am
    Many thanks Diego, ive just tried it, its a pretty good workaround. I have to say tho, ive been using After Effects for ten years and I never knew it had an auto keyframe function.
  • Dmytro Korolkov
    October 29, 2020 at 11:25 am
    Thanks a lot! This is the best solution I’ve found on net! Creating keyframes on several shapes from hundreds is so time-consuming
