Activity › Forums › Apple Final Cut Pro Legacy › Add setup when exporting
  • Add setup when exporting
    Posted by Matt Larson on December 1, 2006 at 7:39 pm
    Typically when I lay off to tape I use an IO or a Kona card and it handles adding setup for NTSC on output. But if I Export the video to send a digital file through FastChannel (a delivery service) what’s the best way to add setup in FCP?
    Jeremy Garchow replied 19 years, 10 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    December 1, 2006 at 8:34 pm
    Why do you want to do this? What do they do with file? Play it out analog? If so, their gear should add setup on their end. If you are working in a digital pipeline, keep it setup free.
    Jeremy
  • Matt Larson
    December 1, 2006 at 9:35 pm
    I have a call out to them, but judging by the betacam I got back, they do not add setup on output. I am very surprised by this since it is a national spot delivery company. Supposedly everything has passed their QC too… yikes!
    Is there an easy way to apply a filter above multiple video tracks? You can do something similar in Avid. otherwise nesting is my best option I suppose.
  • Jeremy Garchow
    December 1, 2006 at 10:08 pm
    Yeah, there’s no adjustment layers in FCP. You must nest if you have to add setup.
    Jeremy
