Activity Forums Maxon Cinema 4D Add Segment to a cube after made editable
  • Add Segment to a cube after made editable
    Posted by Joe Bodego on June 3, 2016 at 2:49 am
    Hello, i created a cube with 4 segments on each axis then made it editable, i then realize i wanted to add 2 more segments, how can i do that. Just learning this program, thanks…
    Joe Bodego replied 10 years, 3 months ago 2 Members · 2 Replies
  • Michael Goldberg
    June 3, 2016 at 4:29 am
    You can select all your polys, and select mesh/command/subdivide.
    If you only want more polys in certain areas, you can use the knife tool to create more edges.
    Mike
  • Joe Bodego
    June 5, 2016 at 8:37 am
    Thank you so much for this, it was a little touchy bu i got it by setting the knife to “Loop”
